Ok...Here's the fix
- Turn on
- Turn the programmer to P2 .C (thats the cold setting)
- Hold down buttons 2 and 3 (thats top right and bottom left) at the same time for about 3 seconds....
- '00' should display
...and you should be able to use it again...
I have no idea what F7 is, but you need to look after this Josh...it is highly likely that you won't be able to get it fixed if it breaks and that means using an appropriate dose of a very low sudsing detergent...don't forget American detergents are for very large capacity machines. The owners manual for this states you should be using a 1/2 dose for an equivalent European sized machine....
...to that end, I would dose at 1/4 for American detergents and about 1/3 for OMO Matic....
