Look who's cooking with gas!
gansky1
May 2, 2001
13,157
Omaha, The Home of the TV Dinner!
Some of you already know I've been working on this range for some time now, we finally got the gas line connected and all the final adjustments made to the Maytag Dutch Oven range and we're cooking up a storm now. So far, I've really liked cooking on the gas, it has some very powerful burners, the Giant Burner on the left front is amazing!
I have to crop them carefully as the kitchen is a MESS!!
The "Dutch Oven" is an automatic cooking system, that uses retained heat to do the cooking. The oven is insulated with 40 lbs. of rock wool insulation and has a timed shutter & valve system that turns off the gas to the oven when the set time has elapsed on the 2 hour, wind up timer. The oven uses the residual heat in the oven to cook the food, or keep it piping hot.
cooking with gas!
Greg,
The Maytag is absolutely awesome. This is very unique in that the burner controls for the gas jets are on the rear of stove. Best of Luck with this Gem. I hope to chat with you soon.
Peter
Now thats a beauty!
That stove is beautiful, and just in time for the Holiday cooking and baking!
I have natural gas in my house too, and after growing up with and having apartments with all electric cooking, I like the gas much better, and I find my gas range much easier to clean.
Don't get me started on the gas company though, I've been having problems with my furnace the past few weeks, and learned last Friday that the gas line from the main into my house is clogged and needs to be replaced. UGH! So far nothing's been done, and I am on a temporary line thats patched into my next door neighbor's line somehow. No word on when they will come fix this either, and we've entered our first real cold spell here in Chicago.
It was very interesting and fun working on this range, I was a bit nervous having not worked with many gas ranges before but once I got into it, it was fairly simple how things were put together. I was lucky with this particular range, it wasn't too greasy and nasty, but the other one I had for parts was disgusting! The bulk of my time was spent disassembling and cleaning parts. I highly recommend the vintage range valve cream from antiquestoves.com, it makes the valves like new again.
Louis, there is a burner under the deep-well cooker in the back left corner. The well cavity is tightly insulated above the burner level and there is an opening at the back of the range for air. The deep well is quite interesting as well, they use a self-lighting "low burner", like a pilot, under the pan as well as the standard burner for cooking. When you are finished cooking with the regular burner, you can set the knob for "lo" and keep the contents of the pan warm as long as you like.
The knobs on the top are just like knobs on the front of a range, turn right for on, back to center for off. They are quite handy to have at that level and since they're in the center of the top, you don't burn the hair off your arms reaching over. Maytag did not make this range, it was sourced from a range company in Indiana. I think something happened to this company because around the late 50's, all mention of the ranges was gone from the service updates from Maytag and they were no longer advertised. I in the early 60's, the Maytag service dept. began begging for parts that dealers may have had on hand to be sent back to the factory.
Thanks for the offer of service literature, Jimmy, I was lucky to find some on ebay for the ranges which was very helpful.
Stunned
I am stunned, just stunned, do you hear me? Stunned is the only word I can use to describe how stunned I am...(Ya ya Blanch we get the picture.)
...to see a Frigidaire deep well pan in a GAS stove. Where are Jesse Helms and former attorney general Meese when real porn hits the web? They will recognize it as an unnatural coupling if they have ever seen one. It is an action that will destroy society and bring on sickness and early death. It is a mixing, not only of brands, but even of different energy sources.
Maytag also made refrigerators and freezers from this era. Ive seen a couple but never owned one. Anyone have any info as to who their manufacturer was? I was told they were made by International Harvester for Maytag and that they were very good refrigerators....... Wonder why Maytag diversified their product line like this in the early 50's only to abandon it. Perhaps because of the 1958 economic recession or perhaps they just were not profitable enough?
Wow Greg the stove looks just beautiful in your kitchen! You will have to let us know how you like cooking with gas after you have used it for a while.
GORGEOUS..
Greg you are an amazing man....marry me! (Anderson Cooper who?) Besides Omaha has a "Twin Towers" (insert sad emote-icon) and an "Empire State Building"... I will feel right at home.. LOL
BTW gas valves for the top-burners on a gast stove are no longer put up there to prevent loose clothing from coming in contact with flames. Beware of bathrobes, ball-gowns and mu-mus!
On electric stoves if is probably deemed safer to have the control knobs on the back-splash panel away from inquisitive little hands since flames are not an issue, and the need to frequently visually inspect the knobs to know where the heat-level is set.
Will you be keeping your fabulous Frididaire electric range? Trust me the heat gas cooking puts off/out in summer is a big no-no!
Stunning, really gorgeous! I had no idea Maytag made non-laundry appliances back in the day. Did they do refrigerators, as well? I was under the impression they expanded into the whole kitchen line in the late 70's or early 80's. Again, one learns something new every day.
A beautiful range, Greg!
