passatdoc
I might add that most of the Frigidaires, from 2140 up, are all 3.5 cubic foot capactity and all are pretty much on the same 27 x 27 inch footprint. So they are easy to fit in tight closet or clearance situations. The 6700-7000-8000 are I believe about 1.5 inches deeper due to the fancy, thick rim on the door, but otherwise are sized the same in terms of the cabinet. All of them are stackable using the Frigidaire bracket. Stacked units can be freestanding or built in. Larger units like Duets or LGs CAN be stacked, but because the units are 40" rather than 36" high, the top of the stack will be 6'8" or 6'9" off the floor.....not good unless you are 6'4" or taller!
