looking for the modern equivalent of a vintage kitchen aid dishwasher
pliney
Active member
Apr 16, 2019
28
North Carolina
Is there a modern dishwasher capable of keeping up with a 5 load a day workload? I've been buying vintage kitchen aid dishwashers for years and keeping a back supply for parts. But eventually they've all had an issue I'm not willing or able to fix (usually with its brain). They are getting harder to come by and I'm currently out of a dishwasher and debating buying something, if there is even something out there, new or resigning to handwashing. We have a small farm and so there are a lot of pots and dishes from milking, canning, and preserving and we cook from scratch for a family of 8. It just adds up to a lot of dishes. Big stuff I hand wash but for the smaller things that will fit, it's nice to have a dishwasher to keep the sink and counter cleared off.
I have a used speed queen washing machine. Is there something along those lines in dishwashers? Are there industrial dishwashers that can be used in residential under the counter space? We have well water that clogged the sensors on a Samsung so anything with sensors is probably not an option. That's why I went to the vintage kitchen aids. Are there other vintage brands of dishwashers to consider? I'd appreciate any ideas of what to look into. Thanks
You could get a Miele Professional dishwasher. They have integrated water softeners that will soften your well water and they have very fast and powerful cycles. You'll ideally want to install a 240-Volt, 30-Amp circuit to take full advantage of the super fast cycles. Although they are also available for 120 V, 15 A if that's all you have available.
Thanks for that suggestion. The issue with our well water isn't actually that it needs softening, it's that there is sometimes enough fine sediment in it that it eventually clouds the sensor. I'll take a look at the Mieles. Thanks.
We stay at an inn in southern Vermont which has two Bosch residential dishwashers flanking a double sink/disposer. Their needs are a little different (given that they're feeding breakfast to 12-15 people and need commercial-type sanitation).
There was a research study for the public health department done in Ontario that said for small commercial uses like a group home, B&B, inn, etc that a domestic dishwasher with a Sanitize (i.e. hold to proper NSF temperature) button was perfectly adequate for sanitation and that a commercial dishwasher was not necessary).
My recommendation would be to take your dishes to the store and fit the dishwasher to the dishes, and then potentially get two. (my older Bosch fits Corelle perfectly; a newer one
I agree with Jamie. You could install two residential dishwashers and use the 1-hour cycle for light/medium loads. Really encrusted stuff can go on the heaviest cycle. The cycles would be considerably longer than a Miele Professional but you'd have two machines rather than one.
Would a sediment filter on your incoming water supply remove the sediment? It would be difficult to find a machine without a sensor. How was it determined that the sensor was damaged by fine sediment?
I had a warranty on the Samsung from Lowes. When the repairman came out he said that a clogged sensor was the issue and that well water voided the warranty. I was refunded what I paid for the warranty but not the machine. It was a long while ago so I don't remember the details and I've let my frustration about the situation go, though the dishwasher is still stored in the outbuilding in case someone wants it. It just needs a $70 sensor part replaced.
We looked into a house filter for our water and it was price inhibitory and the water suits our needs in every other way. You are right, probably all the new dishwashers have sensors. I'm going to have to stay old school, pre-filter. And there's not room in the kitchen for two dishwashers. I'm getting pretty fast at hand washing! thanks for the ideas
Ah right I see. I don't know much about well water or extended warranties, as I have neither. Thanks for explaining!
Following on from what Jamie said about the Bosch, another good inexpensive option is to look for a used Bosch dishwasher. Every single washer, dryer and dishwasher that I own was purchased used. It would be great if you could find one for sale that has the "Speed 60" cycle (or equivalent) as this would make short work of most loads and would give you fast turnaround times. Then you could use the heavy cycle for the really tough messes.
You can't go on without a dishwasher for long!
Mark
Just keep getting KDS 18-20 series Kitchenaids and fix them. Timers and program switches show up for the KDS 18, 19, and 20 models on a regular basis. Other than timers and switches, most parts can be swapped between those 3, especially the 19 and 20 models.
I am on a well system also. I have a whole house water filter system installed right after the holding tank. You can buy them for less than $100 and are easy to install. The filter needs to be replaced based on your water usage but are relatively inexpensive. The ones I use remove sediment and are about $10-11 each. I live alone and change the filter every 10 weeks. I know it needs to be changed when the water pressure decreases.
I’m not sure there’s any modern dishwasher that would hold up very well to five loads a day, also when you consider the 2 to 3 hour cycle time of new dishwashers, the thing would be running all day.
You might consider a commercial machine they don’t do a very thorough job, but you have to pre-rinse everything but they’re extremely fast just five minutes or so.
The problem you had with the sensor in the Samsung I doubt if it’s related to the well water unless it’s a defect in Samsung’s the type of sensor that whirlpool KitchenAid use currently would not be affected by a little bit of grit from the well water, I suspect they were making excuses for a very unreliable dishwasher to begin with. Samsung dishwasher seem to give us more trouble than about any dishwasher and people seem to give up on them very quickly.
If you’re gonna go with another used domestic dishwasher that’s faster. Look for a whirlpool power clean or Kenmore ultra wash dishwasher built between 1985 and about 1995
These do a stellar job in about an hour boost the water temperature if needed and have no sensors to give you problems
John L
I agree with combo I was just going to say the same thing. Find a Kenmore Ultrawash or Whirlpool equivalent, the Powerclean module dishwashers. Incredibly powerful dishwashers hence the name “powerclean” and notoriously reliable. They are everywhere on the used market. It’ll be a much cheaper solution that can handle as much as you throw at it and they are simple to work on if that would ever be necessary. Also easy to clean and they keep themselves clean mostly. They began production in the mid 80s and ended around the late 2000s. They are the only somewhat modern equivalent to the old Kitchenaid dishwashers, infact since Whirlpool began making kitchenaid back in the 90s they made a kitchenaid version Powerclean dishwasher which was the same as the Kenmore and whirlpool models but all stainless inside and more elite, I see those on the used market all the time, I’ll attach some photo examples of what to look for if this interests you as those are the machines that could handle being ran and ran and ran, they are notoriously reliable I’ve had mine for about five years and it’s ran a lot and it’s never had one problem. Highly recommend this, you will not be disappointed. If you go this way, try to find one in clean like new condition, no rusty racks, clean inside and out…they also made portable models which are the same as the built in version but it’s on wheels in a portable frame with a counter on top which is what I have. Also older Bosch dishwashers are another very good option and quite reliable, they certainly aren’t as powerful as the Whirlpool Powercleans but they are very good dishwashers and hold up well. Bosch nowadays is really hit or miss and isn’t worth the money.
    1 MB
    1.2 MB
    741.3 KB
    1.4 MB
    1 MB
    888.6 KB
    1.4 MB
    1.4 MB
    1.1 MB
    2 MB
Didn't Maytag make one similar under JetClean? I thought there was a Whirlpool version under Maytag for a short time.
No that was true Maytag at the time. Whirlpool never came in the picture for Maytag until 2006. Then in 2006 when they bought out Maytag they continued Maytags design for the dishwashers, then made the point voyagers, and next came the last good generation of the Maytag dishwashers 2015-2020 which would be a very good pick
It seems everybody, even Maytag has reverted to that alternating wash arm action.
