looking for unscented/low scent powdered laundry detergents that produce few suds
emmach
Active member
Jan 6, 2021
33
New Jersey
I have an issue with suds coming out of my standpipe during the final spin using tide powder f and g. I use less than the recommended amount but it doesnt help and I cannot use the standpipe adapter that comes with my speed queen because it is too small for the drain hose extension that I had to have installed. Can anyone recommend an unscented/low scent powder which is very low sudsing, ideally containing oxygen bleach? The liquid version doesnt cause this problem but Im told it is not good to use liquids exclusively. Thanks!
wd40
Thanks, Tom. May I ask how far down you recommend wiping it as I read that WD40 repels water. Also is it recommended to remove the WD40 at some point?
The suds is because of the spin.
Even the lowest foaming of detergents will produce this spin suds.
All detergents here in Europe (where they are all low foam) do that too especially in spin drain machines vs neutral drain ones.
I had this problem.
As it increase the speed it whips the suds and if you have a tall elbow siphon and the drain hose is not sealed will back up as it is unable to go past the siphon unlike plain water.
Sadly the oil effect will vanish a lot as soon as first water pass through,  but the problem is in the last water drained as the spin speed kicks in stronger.
Try to seal the drain hose where it enters the stand pipe with a fine rubber ring or rubber gasket to have the hose pressed sealed tight into the stand pipe.
No suds will go out.
This is not a matter of detergent, some loads also tend to produce more spin suds than other.
Heavy towels for istance.
[this post was last edited: 6/7/2021-14:16]
@kenmoreguy89
Thanks. Can you possibly recommend a particular rubber ring or rubber gasket that you mentioned? Tbh, I dont quite understand what you mean by the elbow siphon as I dont have a siphon break on my hose.
The size of the ring really depends on the size of your standpipe, so as you say that the adapter that came with the machine is too big for your pipe you need to chose something thinner that would fit and create a gasket.
The gasket on Amazon that i have posted looks more thin than the Speed Queen adapter, anyway there are measures on one of the photos.
The siphon I am talking about probably is under the floor and or before entering the main drain line.
Siphons are there to avoid stench and or gases from the drain line or septic tank to come up the pipe.
Especially in a standpipe for a washer.
If the elbow of the siphon is tall or S shaped suds will Just not pass but tend to accumulate inside the pipe before the siphon and come out from where the hose enters without being sealed with a gasket.
adapter
sorry I didnt see one of your posts before I responded. My standpipe is not too small for the adapter that speed queen provides, rather the hole in the adapter for the drain hose is too small because I needed to have a drain hose extension installed and that involved replacing the section of hose that would be going inside the adapter. I'll look around for something like that which you posted. Thx.
