I would assume there is there a pump that recirculates the w
No there isn't!!! I had no idea about how this machine worked until now. This is a very interesting machine, according to the patent:
"By maintaining a predetermine liquid level in the bottom of the tub during the discharge of liquid under pressure though the unions (#46) I am able to continuously recirculate the detergent-containing water liquid in the bottom of the tub through the partially submerged aspirator passageways in the discharge unions (#47)."
Correct me if I'm wrong Lou, but what I take from that description is detergent is placed into the wash tub with the dishes. The basket sits on a strong bearing and is easily turned (see my color illustration below). The water is turned on and sprayed onto the dishes out of the blue jets causing the dish rack to turn. Once the water level reaches up and covers the red part of the jets the detergent laden water is sucked into the aspirators and mixed and sprayed with the never ending fresh incoming water. During the first few minutes of wash (after the water level reaches up to the red aspirators) the water is heavily detergent laden, but after seven or eight minutes the detergent laden water has now become very diluted with fresh water to the point that the dishes are slowly but surely rinsed.
The knob on the left controls the water through the spray. The knob in the center opens and closes the drain which is similar to a bathroom sink basin drain with an overflow opening at the top. The knob on the right seems to control a hydraulic lift to lift the dish rack upwards. According to the patent:
"During the elevation of the shaft (that holds the dish rack), the anti friction bearing member permits any angular momentum of the dish container and its contents to continue the rotational movement of the container for a substantial period of timer after the rack has been elevated to its fully raised position so as to dry the contents thereof by inducing the movement of air around the articles therein having surfaces exposed to contact with the atmosphere.
Very fun! Another machine like Frigidaire, Apex or ABC who's design is one that stands out from the crowd.
