And Another Thing . . .
Remember those cheap bottom rack glides Nate mentioned in the WCI thread? I think the Thermador could have benefited from a similar design. Even when just partially loaded, the bottom rack would almost immediately run off one of the rails and get stuck. We regularly had to reach across and over to the rear corner and lift the rack back into place. And those same casters that de-railed also served to wear away the door gasket on both sides, as can be seen in the attached picture. Once I had conquered the reliably exasperating lower rack with the pictured BobLoad, I was so over that machine.
