hydro flex damp dry
The way I read it, water goes under the flex tub which presses in against the clothing. Outrageous - must be similar to an agitamer and the force those things can develop.
I think the pump is similar to the type used in an economat, being a eccentric pitman type. And I suppose you could say the timer mechanism is in some ways similar to a Blackstone, as it appears to be mechanical.
I wonder what the HP pump is too - it seems to have high pressure fittings of some kind on it - maybe an air pressure actuated clutch or shifting mechanism hiding in there somewhere? It probably does have something to do with that truly 'kabonky' extraction bit.
Extremely cool scans.
Rich - thanks for doing that.
Holla from Hollywood
Bob
