Frigidaire Deluxe
Active member
Ok, so there's this problem with my Australian Hoover 460. a piece has broken in the suspension. this is most likely due to faulty repairs (at least one side) where you can see a previous repair was done with a washer way too big for the pivoting joint. I've tried 3d printing parts but with not much luck as one has snapped. could be due to my design (will try something later) but if there are any original parts floating around id like to have them. Both of the parts are damaged, one is in better shape than the other.
I've also thought of making the same part in metal in a lathe to give it no chance of breaking but it could cause the suspension to behave weirdly. photos of my design and the parts below.
