Do I have neutral drain ?
Nov 24, 2025
22
My Kenmore/ Whirlpool direct drive washer is from the mid 90's ... reading the posts I think it should have the neutral pump out of the tub prior to spin. If it does -- has not worked for a couple of decades. How do I check .. and fix? New trans/ gear box?
110.92599200 S#1606333
Your machine was built with neutral drain. You might have a transmission problem , it was fairly common for certain periods of production of direct drive machines to have a problem with the transmissions neutral drain pack.
The machine will go on working fairly well without doing the neutral drain of course you’ll have more lint in your clothing and smaller loads are more likely to go unbalanced but many tens of thousands of these machines go on working the rest of their life just fine without the neutral feature.
John L
