gefilterflew
Okay, so here's what happened.
I accidentally shifted my 1991 WWA8898MALAD into GENTLE while it was already running.
Yes, yes, I know it was stupid.
I intended to raise the lid and then push the cycle change, but unfortunately dropped the lid as I grabbed it, and still mashed the cycle button before I could stop myself.
Because #Klutz.
Ugh.
SO. Now, I've got a lot of noises. Even when I don't use Gentle, but leave it in normal, you can hear clicking as one part in the clutch spools up. By the time it's going fast enough to drop into high gear, the clicking stops.
Spin cycle is fine, very little noise, EXCEPT... I learned something today... after spin stops, the motor stops, and the trans engages the brake, you can hear some part of the clutch spooling down. Is this the carrier plate maybe?
But whatever it is, you can hear it hitting something... CLACKCLACK. CLACK CLACK clack clackkk.
So how screwed am I?
Some runs, it doesn't make much noise at all,
Other runs, it makes lots of noise every time it does a new thing.
How long will the machine run in this condition?
What can I realistically do about it?
Can you still find NEW clutches for these monsters? My local appliance parts stores interrupt me when I say I need parts for a GE FilterFl.......NO, we don't stock anything for those machines.
To be honest, I've had some level of clutch noise for quite some time. But now, it's a couple orders of magnitude worse. And I never had ANY noise on the normal setting.
Thoughts??
Thanks folks!
Because #Klutz.
Ugh.
Thoughts??
Thanks folks!
