smokeythecat
I’m replacing the cord of my washer and decided to open the motor to clean out the 80 years of lint I can see through the vents. I took out the 4 long bolts but can’t figure out how to get the two halves of the shell to come apart (yes the pulley is off, and I tried hitting the shaft with a hammer). Also wondering what I should put in the lube ports for the motor shaft. Vaseline is what we use for sewing machine motors, which are considerably easier to take apart (their center bands aren’t welded together so it’s easy to get a screwdriver underneath to pry the motor shell apart)
