Maytag 641C dryer
I replaced my motor pulley a week ago. The old was was worn down significantly, slowing the dryer down as the belt slipped. I replaced it with a NOS steel one and it made a HUGE difference. The dryer performs much better, speeding up dry time on average 10 minutes. Definitely change out the motor pulley.
Well now that the holidays are over, I once again continued with the dryer. Replaced the motor pulley and converted the dryer to 110-120 so I could see if it would run. It did, but one items that didn't work was the timer. It would not advance. Nor will the bell ring when I advanced it to off. So, need to find a replacement timer. Interesting that the time housing itself is missing the model number. I can't, so far, remove the screw in the front of the dial. It's stuck. Maybe it's there.
I did pull the timer itself. Maybe I can just replace that. [this post was last edited: 1/11/2014-21:05]
Timer Problem
It sounds like you may just need a timer MOTOR, if you could post a picture of just the motor I can see if I have one, a picture of both sides of the timer motor and whether it is a CCW or CW turning motor and the number of teeth on the little gear on the TM would be helpful.
The bell will ring when you manually rotate the dial. The dryer has to be on the Wash n' Wear setting for the bell to ring. The contacts that ring the bell are very small in the switch housing and fail quite easily over time. I even bought a NOS timer and the bell contacts didn't engage. I had to disassemble the timer switch and set/align the contact spacing myself. If you like tinkering with mechanical electronics, I suggest you disassemble the switch yourself. Most likely, all you will need to do is some contact cleaning (fine grit sand paper and rubbing alcohol). It can be tedious work though if you need to set the contact spacing as the contact spacing has a small margin for error.
Thank you Bob331. I don't think I had it set on wash and wear. I will try it on that setting and see if it rings. My luck I will have to take apart the timing housing.
Also, still looking for a timer motor.
Completed
Finally completed the 641C Maytag electric dryer. I want to thank John (combo52) for his assistance and parts I needed to complete this project, plus everyone else for their assistance pics and video below:
The one thing that I always do is...
...take a fairly thick felt drum seal, and using hi-temp glue, glue it around the outside of the drum lip so that all of the heat from the elements go through the heat holes in the front of the drum. This will also keep anything from falling into the heaters from the inside of the drum. Sorry I didn't mention this earlier, but haven't been on in a while.
