Once i forgot mine filling, the water went 1 inch below the top of the spin basket.
It didn't leak, but it was scary... how would I drain all that water?
I opened the valve and used a small bucket that I use for my spin dryer to remove 3 or 4 buckets of water from the washer, waited some time to lower the level in the spin dryer, turned the selector to spin-drain and used a screw driver to turn it on. I was really afraid it would either throw water everywhere through the top of the cabinet or break the belt. Nah... it drained smoothly then after the spin dryer tub was empty i drained the washer... crisis controlled.
John, thanks for the info. I never opened the front of my A-50 so I have absolutely no idea how that specific diverter valve looks like or works, but I imagine there should be a rubber seal or anything that looks like a stopper.
Your information clarifies a lot, so I was doing the right thing, right?
If the rubber gets deformed due to the pressure and starts leaking, for the spin tub is almost irrelevant, but for the wash tub it would be a disaster.
No spin dryer is made so fragile that wouldn't stand that, however, considering it's age, I would never intentionally fill the spin drum with water.
