Maytag A108 belts, is this right?
alr2903
Mar 5, 2003
5,271
TN
Maytag A108,  I received my belts from flea bay. 211125&211124. Is this the correct belts?  I have no agitation but the motor is running,  spin works, tub revolves and pump drains tub.  If these are the right belts is the transmission seized up? when I turn the belt by hand the the tub revolves both ways, but turning the large center pulley on the bottom in either direction does not move the agitator.  Thanks alr
Non Agitating MT Washer
It does indeed sound like you may have a sized transmission. The shaft the agitator fits on can size in its bearings when a small amount of water eventually leaks into this area. This is about the most common reason that we have to condemn helical drive MT washers as they get older, we still see a few of these every month and this is when they we sell a new SQ TL or FL washer, nothing lasts forever that has anything to do with water.
