halifaxdiana
- Joined
- Apr 20, 2011
- Messages
- 3
I've owned a Maytag A108 since 1980 and it's never given me a bit of trouble. But now it has a constant mildew smell.
- I keep the lint filter on the agitator clean, so it's not that.
- I've run bleach through the dispenser, so it's not that.
- I've pulled the drum off center as much as possible all the way around and wiped out all the lint that I can reach from the top of the drum under the top/casing of the machine.
- I've reached in and under and up to the top of the rotating drum and cleaned there.
- I've shone a flashlight through the perforations to see if I can see a sock or rag caught between the two drums, but found nothing.
- I've run a coat hanger under the agitator to see if a sock is wound round the agitator stem, but nothing seemed to be there.
- There's no evidence of a leak or drip anywhere.
- My only change in detergent was switching from powdered detergent to liquid about a year ago, when powder became hard to find in the stores. The mildew smell didn't start until about a few months ago, almost a year after the switch.
- I have been using the machine almost daily in the past months (due to an aging dog with incontinence), whereas before I used it about once a week for two or three loads. But when I purposely don't use the machine for several days, to try to let things dry out, the mildew smell does not seem to decrease.
This may be irrelevant, but here's some added info: Some fix-it forums say the (generic washing machine) drum should rotate in one direction but not the other when at rest, but my drum won't rotate a bit in either direction. I'm having no trouble with spin speed or draining.
Any ideas?
I'd hate to get rid of a machine that is still working fine after thirty years, but the smell is driving me crazy.
- Diana -
Any ideas?
- Diana -
