Maytag A108S problems
woodsong
Aug 19, 2013
4
An oldy but goody. 30 years of trouble free service till now. Some times it goes thru the whole cycle but then doesn't drain or spin dry. If I spin the dial all the way round to the end of the rinse cycle it will sometimes drain and spin. Yesterday it took five times before it kicked in. Also it has been known to just start on the next cycle (delicate). It sounds like the timer mechanism to me but when I was at my local appliance repair guy he mentioned that after a lot of years the transmission gets stuck and needs greasing. I took the front off to do that and was intimidated by the size of the transmission and where to put the grease. Any help or suggestions would be appreciated. Peter
Not the transmission!
Could be a timer. Not too bad to replace at all. Might be a bit of money, but that's why ebay can be great. Does the washer agitate during the wash portion of the cycle?
Dave
maytag A108s
Sorry for the delay. Yes it agitates. In fact it does everything just fine until the final rinse. Think I'll replace the timer to start with. Thanks Peter
The problem with the final spin could be in the timer.  I do find it slightly odd that there isn't a problem with the drain/spin between the wash and the rinse.  Have you noted whether or not the machine actually drains and spins between the wash and rinse? Also, when you say that it's not draining or spinning is the motor running and nothing happens or is there silence?
Most often when a contact burns, pits or otherwise fails to close in a timer it does so EVERY time that action happens, not just in one spot on the dial.  If this is the case on your timer, the bad contact is most likely the one to the motor reverse start winding.
When it automatically goes into the next cycle does it start to fill or does it dry agitate when the next cycle begins?  If it is dry agitating without filling first you will also want to check the water level switch.  If this switch sticks in the closed position the timer motor will continue advancing at the end of the cycle.
It doesn't sound to me like there is anything wrong with the transmission in this machine, particularly since the transmission is not even used during the drain/spin process!  In a Maytag machine the transmission is used only to operate the agitator.  The advice you got from the appliance guy is very odd as there is absolutely nothing to grease in a Maytag washing machine!  Anything that requires lubrication is oiled with either turbine oil (pump bearing, spin bearing, radial bearing) or a heavy weight motor oil (brake package, interior of the transmission).
Good luck and let us know how things are coming along!
Yes, it does drain and spin between wash and rinse. When its not draining at the end of the cycle the motor is not running, all I hear is the timer. When it runs to the next cycle it fills again, does not dry agitate. Thanks Peter
I would certainly go ahead and replace the timer.  It sounds like you have worn or pitted contacts.  The cam may be JUST enough different or worn at that spot on the dial that the motor reversing works in other spots but not in that one.
One trick you will have trying to find a timer for this machine is that it's a suds model and those timers tend to be harder to find since there were far fewer of them made originally.  If you no longer use the suds saver feature you can go ahead and replace the timer with a standard one.  Here are pictures of AND part number of the timers that were used on the A108 machines.  The top two timers were made by Kingston and the bottom one was made by Mallory.  They function the same and the console was designed to accept either timer.
Thank you Kenmore 71. I went ahead and bought that one on ebay. Before I did that I took the old one out and pulled it apart. I cleaned up the contacts and filed the contact levers flat as the 'regular wash' ones had developed grooves in them where they run against the rotating controlling disc, the black one with raised sections on it. Put it all back together and it has worked well twice so far. We'll see. At least now I have a backup. Thanks all for your help. Peter
