smokey2367
My name is Doug and I'm working on my first washer project--my old 1970 Maytag A206 Washer. I'm working on the transmission--mine had two bolts and a snap ring holding the pitman arm to the pitman gear. Apparently I didn't remove to bolts correctly because they both broke off in the gear. Has anyone else had this happen and is there a way around it or am I screwed?
Thanks for looking!
Thanks for looking!
