Hello All!
I am the lucky owner of a Maytag A208. It has stopped working in the past few days. I did some troubleshooting on the phone with my uncle, and I decided to replace the timer switch. Well, $120 later, the problem still exists.
The washer will start a cycle just fine and fill with water of the right temp. When it kicks on to agitate, it overflows. I cannot tell if it is still trying to fill, or if it is just spinning the water out of the top. If I let it go, it will fill the bleach cup and then overflow. I can manually advance the dial to make the water drain out. Any ideas? Now that I have spent this money on the old thing, I have to fix it. I took the front panel off and everything seems OK. I made sure the pump was spinning freely and the hoses were not clogged.
Any assistance would be greatly appreciated!
Thanks,
Tim
Thanks,
Tim
