Maytag A208 Timer Trouble
automatt
Jan 4, 2012
12
I have an A208 Maytag that works well but the timer does not advance automatically.
I took the timer motor out to try to replace it first.
This has a small brass gear instead of the larger plastic ones I have seen.
The timer number is 2-4454-1. The motor is 28058
Does anyone know where to get a motor like this or if it can be fixed?
timer motor
the timer motor detaches from the gearbox bt turning the motor while holding the
gearbox-takes about 1/8 turn to unclip the motor,but i do not remember which
direction...Once seperated,you can oil the motor's rotor shaft-oil may have gotten
gummy,stopping rotation of the very low power timer motor.
