A606 Maytag Timer Won't Cycle
r8f1k
Sep 19, 2024
13
Grayslake
I am new to vintage washing machines, but I am experienced with mechanical items and electrical equipment. I recently bought a nice condition A606 washer that 'works'. The machine will cycle manually and operate on all functions if you turn the dial manually. Very clean, runs nice and smooth.
I took the back control panel cover off and I could see that the timer motor was NOT turning. I was able to track one down no problem, swapped it in and it still would not cycle through the functions as I thought it would. I took the timer mechanism apart and I found one burnt contact.
I took 400 grit sand paper and cleaned all the contacts, cleaned up the interior of the mechanism and reassembled. The one burnt contact, I sanded as clean as much as I could, there is still plenty of material on the contact. I ran a continuity test on all the contacts, so far so good.
I installed the timer back into the machine, same problem. No cycling through the functions. I cannot see the round end of the shaft turn at all (has a nickel sized back). I know there is an adjustment that can be made to get the gear to be turned via a pawl and gear. Not sure how to adjust so I just put it back to the same spot the screw was from the factory.
What am I missing? Can't find one on eBay either...... 2-4476 is the number
most interesting
should work with a new timer motor
There may timer damage that cannot be fixed
The other more knowledgeable members will chime in
My 606s timer motor died suddenly too
Only when I noticed that the washer was spinning for about 10 min did i realize the timer was stuck
First off, welcome to the forum!
And congratulations on your vintage Maytag. IMO, they are the best washers ever built. As for the timer issue, I can think of a few potential culprits. One thing would be if the timer motor isn't getting power. It should be getting 120V AC anytime the machine isn't filling. I would also suggest testing the motor outside of the timer to make sure it runs. If it does, then I would suspect a problem with the gears.
Hope this helps,
Thatwasherguy.
So I pulled the entire mechanism apart and the gears have no broken teeth, the new motor runs, but nothing cycles beyond what it was set to.
Since the last time I posted, I bought another washer timer for an A606, but without Permanent Press. It is the 203180 Timer. I also bought the accompanying dial to go with. I would just like to use the unit and I don't have to have perm press to do daily washing.
That being said, does anyone know how to wire the other unit up? Will the wires basically be in the same locations? I know the pilot light, power, lid switch, timer motor, etc will be the same and should play nice, but if anyone had a wiring diagram for the A606 without Permanent Press?
Are you using Kingston timers or Mallory? Permanent Press and non Permanent Press models do not use the same timer motors or the same timer dials, even within the same timer manufactures.
I have the schematics for non PP and PP timers around here. Give me some time to dig them out and scan.
The timer showed up today, Model 2-3180-1 and it SEEMS similar, but the numbers on the terminals are definitely in different locations than the current unit. My question is, if I have a diagram, will it be clear enough to determine what wires SHOULD go where? For example, the wire labeled "16" goes on the lower right side of the old timer, whereas the "16" terminal on the 2-3180-1 timer goes in the upper left.
Is it a situation where the numbers should simply follow one another from point to point, or do they need to be rerouted based on what they are coming from?
I can gather that PL = Pilot Light, TM = Timer Motor, L1 = Line 1, L2 = Line 2. However, the balance of the wires would still need to 'play nice' with one another if a different timer were introduced. Do I need to renumber the wires to work with this unit or should the numbers match regardless?
Here are the scans, the PP model came from a small-ish book so you'll have to download them both to zoom in.
I haven't installed a different timer to work on a different model/wiring setup (I have changed consoles with the wiring harnesses on the same machines) but having worked on different models, most of the numbers match up to the same components and are wired very similarly which is convenient. With the wiring diagrams, it should go smoothly.
If memory serves me correctly, the non PP timer motor advances every 45 seconds vs every minute like the PP models. You lose 15 seconds of a spray rinse.
Thank you, the diagram that is without PP, is very blurry. Is it possible to get a better shot? I can just make out a couple of the numbered locations.
Timer Dials Different
I don't see that Maytag changed the harness part number when they went to Permanent Press on the A606, so you should be able to match numbers on the harness with the numbers on the timer.
Are you currently using the original timer dial from the permanent press timer on the new pre-permanent press timer? If so, the cycle positions shown on the timer dial will not coincide with the timer you are using. As qsd-dan mentioned above, the timer dials are different for Permanent Press and non-Permanent Press timers.2-3174 is the A606 timer dial for pre-permanent press and 2-4481 is the A606 timer dial for permanent press machines.
Yes, the dials are going to be different, I ordered a corresponding dial, but I still have no pilot light, cycles, or motor when the dial is turned.
Sent you an e-mail
I sent you an email with both A606 wiring diagrams as a PDF attachment. Hopefully you will be able to view these better than those previously posted.
Got the diagrams, Thank you! So the reason I did not have power before was an adjustment on the lid switch. Fixed that and now I have water filling solenoid noise, but that is it. The spin motor or agitator function do not work. I am also heavy two extra wires from the previous timer.
One extra yellow '16' from the pressure switch
One extra black jumper '35' from the other unit. Not sure this one matters all that much.
I bypassed the timer motor to confirm it works, it does.
I will dig into these with the diagrams shortly!
Extra wires
My apologies - I was mistaken earlier when I stated that the wire harnesses were the same for both the pre-permanent press A606 and the permanent press A606. The wire harness for the pre-permanent press A606 is part number 2-3233. For the permanent press A606, the wire harness is 2-4475. You are seeing one of the differences now (the 3S jumper.)
Your extra "35" wire is actually marked 3S and on the Permanent Press timer, it is used for fabric (speed) control and jumps from the 3S terminal over to the 32 terminal on the other side of the timer. On the pre-permanent press timer, the 3S terminal does not exist, so you can just tape over the end of the 3S wire terminal on the jumper with electrical tape.
The YL/BK 16 wire is what delivers power to the timer motor and ultimately (through the timer contacts on the pre-permanent press timer) to the motor. This occurs once the water level switch determines the tub is filled to the desired level. So if it is disconnected, that explains why both the timer motor and the main motor are not getting power.
On the pre-permanent press timer, the YL/BK 16 wire should connect to a double terminal on the timer where one of the black wires from the timer motor is connected. It may be marked both TM and 16.
There may be other differences between the harnesses that we haven't caught yet. It is always best to try and get the correct timer in these situations.
Why Maytag didn't rename the 06 models when they added permanent press is unknown to me, but it can certainly lead to confusion when ordering parts.
I have a feeling I am going to have to trace each wire from its location to the timer. I could NOT find the correct timer anywhere. The unit I bought was the best alternative to get this machine going.
Right now I have the "16" Yellow with black tracer, piggy backed onto the other "16" with a double spade connector and a jumper. No change in the situation.
I let the unit sit for a spell and came at it later with a clear head. Still nothing except the solenoids for the water controls. Using my meter, I get 116v on all the terminals when I manually cycle the features with the dial. The timer motor never spins. I repeat, it never spins. It does however work, I can confirm that.
Any ideas?
