I have a Maytag A606 (s/n 300227DW) washer and its matching dryer (DE606?) in white. These were purchased in the late '60's and have been operating in the same location ever since.
I performed the last significant repair on the washer 15 yrs or so ago, using a wrench borrowed from a shop to deal with a leaking tub seal - I only vaguely recall that project.
I have just become aware that the washer is making a knocking sound during the wash (agitation) cycle. This knock is similar to the tick .... tock of a clock and the frequency coincides with reversal of the agitator.
I found out from family that the machine had recently shut down because of an imbalance condition. I do not know whether the knock started following this incident or preceded it.
1) Can the machine be operated with the front panel removed for the purpose of diagnosing the problem
2) Although the noise suggests play or looseness between the transmission shaft and the agitator, I have read that for other machines there are mounting bolts, brake shoes and suspension springs that can be at fault.
For this A606, what areas should be inspected first.
3) While the machine is open and has my attention, what routine maintenance and part replacement is recommended?
Thank you
Ken
Thank you
Ken
