Help! I am a DIY newbie and a first-time poster to this site. My beloved 30-year-old Maytag is leaking from the injector (aka air gap) assembly consisting of a black rubber valve (sleeve), a clear or gold-colored slotted plastic insert (the injector or air gap gizmo--technical term) threaded through a slotted clear plastic cylinder that screws into the left side of the washer to secure and support the two sections of hose running from the water valve to the inner tub rim which the injector/air gap gizmo connects.
I bought a new rubber valve or sleeve this weekend from my appliance dealer and have spent hours trying to insert and reinsert the gizmo into the valve/sleeve and the valve/sleeve into the water hose but no combination of efforts appears to have any effect.
Newbie that I am, it strikes me that the rubber valve/sleeve isn't long enough to thread through the two sections of hose, both of which have a bulb-like widening to accommodate the injector assembly before reducing down. My logic is if the sleeve doesn't extend from the widened part of the hose (this is where the clamps are located) to where the hose narrows, there isn't any chance of clamping the "bulbs" to secure a leak-free cinching of the rubber sleeve. I also don't know if I am inserting the injector/air gap gizmo into the rubber valve/sleeve properly--I have tried 2 different ways--with the lip of the sleeve pulled up and over the flange of the injector, and with the lip of the sleeve flush with the flange of the injector.
Can anyone suggest things to test or point out what I might be doing wrong?
Many thanks,
Fran
Many thanks,
Fran
