Folks I got Revvinkevin's Maytag A700 washer. It's in nearly pristine condition., plus nes motor gliders, new belts and new drain pump.
However, I need some help.
1) could anybody share with me the wire colors for the wash temp push button, switch/rinse temp selector and fill solenoids?
I have either cold or hot, but not warm. And rinse also works only one (I don't remember it the automatic or the cold).
2) is there any way I could get a new valve that would be 100% compatible? (Just in case). It is with the original triple valve, but leaking.. Kevin gave me a second valve, but we're not sure it works and I haven't tried it yet.
3) Could anybody guide me through the lights wiring? Kevin got that washer with all theblight wiring (tub, panel, and dial) disconnected, so I need to redo it. Also, I noticed a small transformer that looks like a doorbell transformer. It's in bad shape, all rusted..... any advice on updating it to something newer?
4) finally, but not least, does anybody know the size of the bleach dispenser cover o-ring?
This is my very first time touching a Maytag top load.
