maytag a700
maytag a700 will not agitate or spin
belts are good. at the start of spin cycle machine makes its usual clunk and about a quarter turn then stops and hums.
so if not belts - ??
Maytags have a usual clunk? ? ? ? ?
at this point, were going to guess, transmission locked up......
can you spin the pulley by hand?.......clockwise=agitation....counter-clockwise=spin
could, but you said it spins and releases fine....
just wondering if its the motor, works OK alone, but under a load, theres not enough strength....
seems odd for everything to work not attached, yet assembled together, and something is stopping it...
if it was just a spin issue, I would almost say theres a sock stuck between the tubs....but since it wont agitate either...
this one is a puzzler
ok. thank you for your advice - this helped a lot. i took the top off and looked for a stray sock - nothing there. ran the spin cycle with just the drain pump belt. all was well. ran the spin with just transmission belt. all fine.
put all back together with a load of clothes. agitation, fine. drain fine, rinse ok.
stopped working on the last spin cycle. just a hum.
same just hum when i turned it back to the first cycle.
motor pulley feels hot. do i need a new motor? motor over heating would do this? or is it a bad solenoid?.
i just took the belts off and put the drain pump belt on by itself. drained fine. put both belts back on and it spun and drained my clothes.
maybe a new timer? i am still puzzled. but i have one load of clean clothes.
others may chime in, but I am going with an overheated motor.....
probably easier to just replace....
usually you can find good deals through ebay...some with free shipping.....
