On my A806, I'd like to remove the damper while the support arms are still attached to the tub. I searched but can't find any mention of anyone doing what I plan to.
I don't think there was any metal rubbing metal, but quite a bit of pad material was hanging out. The inside of the damper seems to be smooth only where it was in contact with what pads were left, so I thought I should try to smooth the whole surface before attaching new pads, and that would be easier with the damper out.
The tub assembly is out of the cabinet and I got the 2 bolts out of each arm but the damper won't easily separate from the arms.
So is it just corrosion keeping the damper from popping off the arms, or is there some feature on the arms or (and) damper to keep them located so that the arms need to be off the tub to disassemble?
Thanks very much,
Joseph[this post was last edited: 4/2/2020-20:56]
Thanks very much,
