If you're going to test for leaks, tape the lid down, remove the 2 screws at the corners under the top panel and raise it 90 degrees. This makes detecting leaks, particularly during the spin cycle, much easier to locate in real time. I test all of my post 1965 machines this way.
I have a bad feeling you're going to find leaks around the band seal during the spin cycle (be sure to test this with a full tub of water). As mentioned above, check the water injector and injector hose (particularly where it connects to the tub) for leaks during the initial fill portion of the cycle, located on the left side.
