Maytag A806
jimmyb
Nov 15, 2004
254
Texas Y’all
I have a Maytag A806 that makes a horrific sound when it begins to spin. I think the problem may be the bearings but when I got machine it had some terrible lime/scale build up. I cleaned it up but think that there is still quite a bit on the underside of the inner wash tub.
Instead of buying the parts I have my eye on another set avialable in my area and my question is that if I buy an A606 are all of the parts interchangeable? Is it possible to take the control panel from one and switch it out with the other, taking into consideration all of the wiring?
Thank you - jimmyb
Maytag swap
Jimmy;
I have swaped several maytag machines washers and dryers it`s real easy .The tubs do not have to be the same size as all the cabinets intercharge. I put them side by side and just move all the wiring and parts from one to another,I would go with the Avocado Green in a heartbeat almond is just too Drab Good luck with the swap John
Bought the Avocodo set on Sunday
They are not in the best shape, the washer cabinet has a few small dents and the washtub has some discoloration at the top. The control panels are in horrible shape but thankfully I do not need them. All in all I will definitely get use out of the needed parts. I will post some pictures tonight.
Classic Gas...DG906
Finally got her cleaned up and running. I just love the blue flame of a gas appliance, seems organic and earth bound as well as etherial. Perfect combination of earth and air at work to dry with, cook with, stay warm with.
