Maytag A8340 vs Whirlpool LA9100XTW1 vs Mid 1990's Amana
SawaSun
Active member
Mar 17, 2013
27
I was never interested in washing machines or other appliances until I bought a couple of rental units that had appliances that were older and worked better than mine. The owners were elderly people who took really good care of things and one can tell the appliances were used very gently/lightly.
My primary washing machine is a mid 1990's Amana LW8303W2 with a stainless steel tub built by Raytheon. Apparently from reading forums, it was equivalent to a Speed Queen. It cleans well but is loud, has a slow wash cycle and the water trickles in and fills the tub very slowly vs coming out very fast in a jet like all at once fashion on other washing machines from the 1990s that I've used. A regular wash cycle on the extra large load setting for highest water use and using cold/cold takes 40-45 minutes vs 15-20 minutes on two other washing machines I've used.
These two other washing machines lightly used by their elderly owners are a Maytag A8340 from 1991 and a Whirpool LA9100XTW1 also from 1991. I am very impressed with how rapidly the water comes out on these and how fast it washes clothes (a cycle being 15-20 min max). To me the clothes come out clean and so far no complaints from anyone else.
I've read that even a no frills new $300 top load washing machine wouldn't be as good as any of the above washing machines from the 1990's because of the lid lock and water level restrictions. I've read that to get an equivalent to better new unit today, pretty much the only choice is a new Speed Queen.
What do you all think of the Maytag A8340 and the Whirlpool LA9100XTW1 vs my mid 1990's Raytheon built Amana? Would it be worth it/wise/a good decision to switch out my Amana with the Whirlpool or Maytag?
I also can't find the cu ft information for any of the above mentioned washing machines. I'm not good at spacial relations but my friend who is says my Amana tub is a lot larger and that I would have to run the other machines twice as much because he thinks the tubs are a lot smaller.
If you have a problem with the water trickling into your Amana it sounds like you may have blocked screen/s in the hoses or in the hose inlets on the back of the machine. It's easy to fix- turn the water off, disconnect the water hoses. Do both hot and cold, check each end of the hoses for screens. There should be one in each hose. If you see they're blocked in any way, remove them and clean them
You must put the inlet screens back in before reconnecting the hoses. They prevent any grit or sediment from getting into the water valve and mucking it up.
If blocked screens are the case...before you connect the hoses back up to the washer make sure you flush out the waterline into a bucket or sink to clear out any leftover sediment in the piping.
Hopefully, this will rectify your slow filling Amana.
Slow filling Amana Washer
Yes it is always a good idea to check the screens at the inlet valve, however this is almost never the problem unless you have a really bad water supply problem in your home. If you find the screens completely packed with particles clean them by gently scrapping and then flush loose particles away, I strongly recommend against trying to remove the screens for cleaning. When metal screens are removed they get bent slightly and if they do not seat perfectly when reinstalled a particle can get by and cause the valve to fail to shut off and you will have a FLOOD.
 If the screens have only partial blockage this will not cause any slowdown in the rate of filling, the screens are at least 50 times larger than necessary for the amount of water that flows through them.
Older is better. However, genuine Maytags have smaller tubs than Whirlpools and Raytheon Amanas. I am not sure about the model number if it goes to a genuine or fake Maytag, but capacity wise the whirlpool wins. However whirlpools generally are not gentle machines, the belt drives were ok but the direct drives are to stupidly designed (short fast agitation strokes)I have never liked the direct drive Whirlpool system. Now, if the Maytag is a genuine one then you are in luck, yes you might have to run double loads, but they are quick, gentle machines, last very, very,very long and are generally quieter than the rest. If the Maytag is a fake with theplastic outer tub please run away from it, those are awful machines longevity wise. I know capacity wise they are larger but I have seen those fail in ways that are just insane for a washer. The Raytheon as others have said most likely has a plugged up water valve, cleaning the screens should help if not replacement valves are cheap, heck they don't even have to be exact. The Raytheon would probably be second to Maytag but I think someone would know better than me how long those would last. Capacity nad cleaning isn't to bad on them, they are worth it too.
Screens Ok
I checked the screens on the hose inlets in the back of the machine and they are fine--no sediment. I have a water softening system, so perhaps that is restricting the water flow on the Amana. Perhaps its an Amana/Raytheon quirk.The other two washing machines are in locations that have no water softening system. The Maytag is genuine with a metal tub.
