jasonlittle
Hey everyone. I just recently got a Maytag AMP automatic Washer. The model number is 121P. And everything works on it except whenever it goes to spin it tries to agitate and spin at the same time and it will not even get up enough speed to throw all the water out of the tub. I took off a cover on the main pulley today. There was some kind of clutch in there and it was completely saturated in oil. I thought for sure that that would take care of the problem but after cleaning it real good with some acetone and putting it back together there was no change in the performance. I am very unfamiliar with these washers as this is the first one I've ever had and I've never even seen one in real life until now. I plan on repainting it and trying to make it look decent again. I believe it is a very bottom of the line model though as it has a Black ringer washer style agitator. If I'm correct the more high-end ones have a red agitator and the Maytag emblem on the front also lights up. I was just hoping someone on here might be able to tell me what the problem is so I can get it fixed and working properly again .
