Maytag Atlantis Electronic Timer
Chetlaham
Mar 11, 2013
4,517
United States
Call me confused, but I've never seen this. The timer appears to be electronic on the back, however it looks like a standard clock dial on the front. Am I seeing this correctly? Does the knob move with the cycle? Just doesn't look like an electronic dial normally does with its individual detentes.
I hate that Maytag took this route, for example those power resistors look like they're dissipating to much heat for their application and size.
https://www.ebay.com/itm/356812918526?_skw=maytag+atlantis+washer&itmmeta=01K2JKVF8GSRV7VK27X1JJZHRS&hash=item5313b50efe:g:SxsAAOSw82ZoB799&itmprp=enc:AQAKAAAA8IUNi59bckQcV2ImusJGAkHE54coTZFG+JW8X08n3zD5ZHKRIlabiH5nev9dRw1Q4iOagJlkDjpA3tk8W42y6nlEW00jBcp2dCDE6Z6nl7/pphROFpA3Z2saQnq0cjHinfRkKRjbm8lSDto+XXlUWejkNsJukeblf3iDpPhBbCgvYVA3UuBjACGShy+3hALd7Bm62GK2q9PYct/B+LXo9iAlA2RAEFvbr3Zfl8WYhxlqQrVjn2HN26fvBR8f0mzVq34e6LK31VB4/4pp1bztRu71akD0PPCSNdhasXPa92byPJSwHaRXJJqL2bUFPmm7xQ==|tkp:BFBMtPTt05Rm
Whirlpool did the same thing, they are not any better:
https://appliantology.smugmug.com/Appliantology/Whirlpool-Dryer-Even-Heat/i-mZQcdRW/A
All a dryer has to do is tumble, add heat, and cycle via a a snap disc thermostat. Yet somehow despite the presence of an EM timer, they had to add a pointless electronic circuit board that adds nothing of value or performance to the machine. I can only deduce this is to help with failed obsolesce because as seen here that control board is a guaranteed service call or trip to the appliance store.
Chet, regarding the other thread about Maytag and electrolytic capacitors.....
In THIS photo you posted, notice the two tall black electrolytics near the bottom of the circuit board?
I can't tell for sure, a closeup of them would help, but the tops of them look a bit bulged - a sure sign of failing, and one looks like it's leaking.
The white resistor on the board nearby looks cooked, and the board is blackened from overheating.
I've got a great eye for things like this.
Indeed you are correct. And such failures are a given with electronics.
You do know that a dryer can indeed be this simple with auto dry as seen below? Not a single semi conductor.
Because it's a SIMPLE appliance doing a SIMPLE job.
It doesn't require some fancy CPU or Integrated circuits to perform such a SIMPLE task.
And the operator isn't going to stand there and watch the pretty LED lights change, or gawk at a little glowing screen with information of what is going on.
They've already got a little glowing screen that they cling to and carry around like it's some sort of life-saving device that they can't put down.
See, this is the culture that is widely spread and has slowly taken over society.
The "conditioning" and continued mental state that's touted as being "normal" and convenient.
And in "some" cases, it is convenient....... for certain things.
I've always said that there is a limit to what technology is good for, past that, it's rediculous, silly, and un-needed.
That evil little "glowing screen".....
All well and good and fun ... how many manufacturers have abandoned electronics or have ongoing plans to change back to mechanical timers in response to the fussing on AW?
How much longer until Chet establishes an appliance manufacturing company, puts his designs into production and takes over the market?
We can only HOPE that appliance manufacturers wake the hell up and realize what a miserable mistake they've made, along with damaging their reputations.
I'm no electronic expert, but that scorched circuit board appears to be using capacitors and a high wattage resistor to convert mains voltage to low voltage DC to power its simple electronics, to avoid the extra cost (and bulk) of a switched mode power supply, or a transformer. The resistor will produce a great deal of heat, scorch the board and will slowly poach the electrolytic capacitors if they are mounted too close, or if there is insufficient airflow. So after some years use, it is practically guaranteed to fail. Had they spent an extra couple of quid or so, they could have made it last indefinitely.
Its not proof that mechanical controls are better, it's simply just another example of bad design and an appliance manufacturer putting cost before quality and reliability.
My gas boiler's control board uses a resistor and capacitors to power a few relays and a simple gate/timer chip, and regularly needs replacing, because the resistor burns a large hole through the PCB and destroys the board, I think I get about 5 - 7 years use out of one.
I wonder if some electronics where added when industry decided moisture sensing is better than thermostatic control in determine dryness of clothing
That was the first application of electronics in dryers. However instead of just controlling the timer motor on the sensor dry cycle (which can be over ridden in timed dry) this dryer decides to take it to way to far by controlling the heater, temperature cycle, buzzer, motor, ect where a simple timer previously sufficed. If anything the timer is really just a decoy to fool the customer.
Personally sensor dry is not always accurate and where it is accurate for the load, I feel that it is just not worth the added complexity. Auto dry is nearly just as good and can be implemented without any changes to the dryer itself. In most cases a single 4500 ohm 10 watt resistor is all that is required. The same circuit that is used in a timed dry dryer can be directly re-used an adapted to an auto dry dryer. For things like sneakers that can trigger the stat to open early can be compensated by adding a bit more advancement time after "more dry" setting on the EM timer.
My Maytag dryer (the match to the A482 washer) has an auto dry cycle.
Not sure of what sensor it uses, but it controls the timer somehow.
Works pretty damn good at determining when the load is dry.
There’s nothing inherently wrong with using electronics combined with an electro mechanical timer.
I don’t think I ever saw a problem with those Maytag Atlantis machines with this type of timer of course the machines never lasted long enough for the control to go bad lol
But if you’re gonna go after people for doing this Maytag first electronically controlled dryer in 1960 combined a timer with a control board and they had lots of trouble with that but there’s nothing inherently wrong with the design. Many other manufacturers combine time with electronic controls without any problem And it made for a more versatile better performing product.
Those whirlpool dryers that can draw combined a control board with a timer or talk rated for their great performance.
I think it’s funny. How many of you guys are making negative comments about things that you don’t work on or never had any direct experience with.
John L
