awesomemariofan
Hello,
We owned a Maytag Atlantis for about 13 years now, and recently it stopped working. The washer for years had a very bad out of balance problem, but when it stopped working it would agitate, but not spin. We tore it down and tried to inspect what the problem was. We decided to purchase a new thrust washer kit, which unfortunately did not fix the problem. We then narrowed it down to the transmission, and purchased a used transmission (which ended up being in a non-working condition when it arrived). This one was returned and we disassembled the old transmission and repaired it ourselves by purchasing a new center gear, and fixed the out of balance problem by replacing the snubber ring. We also gave it a good cleaning. I have attached some pictures that we took of the transmission disassembly.
After reassembly however, the tub had a slow leak out of the bottom of the washer when it was filled with water (even on tiny water level). We replaced the tub seal after seeing that it was almost disintegrated, the leak still continued. After tightening the screws on the seal a bit, it seemed to worked fine (we even left it with water overnight). After a few weeks though, it started to leak again, and upon disassembly it showed that for some reason a couple of the screws had become loose and could not be tightened. We thought that it was a problem with the seal and requested a replacement from the seller we got it from. After installing this new seal the washer still has the same slow leak. I'm not sure if I should just leave it alone and use it as is, or if I should disassemble it again and check if the screws can be tightened more? (Is it possible that they can be under or over tightened?) I really would like to get this washer in working condition again to fully restore it since it works very well, but I'm not sure if I want to spend money on another tub seal and give it a third attempt.
Another detail, if it helps, is that the original transmission was an older model number which I can't find any information about on the internet. The triple lip tub seal which we purchased said it could only be used with a high torque transmission (which I assume is the new 35-6615), however we have it installed with the old one currently, and I am not sure if it is high torque or not. I can post the model number of it and serial number of the washer if it would help. It seems to be working fine so far however.
If anyone can help with fixing the water leak I would really appreciate it!
Thanks in advance,
John
Thanks in advance,
John
