The brake arrived via USPS this morning. I installed it this afternoon, and did two loads in the machine tonight. It works perfectly again, as a vintage Maytag should! The brake started being noisy about a year ago. It didn't screech at first, just made a sort of a moaning sound, as the brake was applied. Then the metal to metal sound started this past Fall, so I stopped using it. I had used oil in it, as directed by so many on this site, however it made no change. John L. stated that the older Maytag brakes were somewhat trouble prone, so I wonder how many of these old models (mine is a 1958) were sent to an early demise because of the brake noise. I mean it sounded TERRIBLE! Metal to metal grinding screech. At any rate, thank you all for the help and advice!
