keng
I'm having problems with my Maytag Centennial washer. The problem is when it's agitating. When the agitator makes it's turn in the one direction it sounds like a clicking noise and doesn't make it's turn in the opposite direction. It ends up just turning in one direction basically, and the clothes are rapping around it. The clicking noise is not terribly loud and it's a little difficult telling exactly where it's coming from.
It almost seems to come from the transmission or gearbox. Everything else is working fine except agitating. Spins good.
I installed a new neutral pack in the gearbox. The motor coupling is fine. The other gears in the gearbox looked fine, and the issue is still present. As far as can tell the clutch looked okay. I didn't think the clutch or brake would cause this issue though. I may be wrong. I then replaced the medium cam and dog ears. The issue is still there.
I've taken this washer apart before and did basic maintenance on it. Cleaning everything and repairing some minor rust.
I've done my own mechanic work all of my life and can usually fix anything on my own. With the internet now, I figured I'd give a forum a try. I'm a little stuck with this.
There's one thing I didn't check. When I had the gearbox apart, the cam and teeth on the shaft looked fine. I didn't check the gear under the neutral pack when I replaced it. Unless someone knows of another part that could cause my issue, I'll probably take the gearbox back out and check to make sure that gear is okay. It's probably not available though.
Any help would be greatly appreciated.
Thanks, Ken
Thanks, Ken
