Summary
Considering it's probably seen a lot of use, this dryer is in remarkably good condition. The area behind the lint filter needs to be taken apart and vacuumed out. The power cord is crumbling and I will replace it before running the dryer (plus I want to use a different plug for it). The front door frame gasket (boot?) is hardened and showing signs of cracking around the edges. It should be replaced but finding a replacement might be a challenge. Overall, it needs cleaning and tuning up, no doubt. The drum turns smoothly, so that's a good sign.
A bit of luck accompanied the transport. When I got it in my courtyard, and opened the door, the upper hinge was loose and missing two screws. Amazingly, I found one of the screws, and the chromed cap nut for it, sitting on the inside ledge of the door. Another chrome cap nut was sitting on the ledge of the cabinet. I measured the screws and figured they were 4-40 x 1/4 flat heads. I was preparing to go to the hardware store and get a replacement screw, but checked the bed of the truck and found the missing one. Oddly, the workshop here has a little box on a shelf filled with almost identical 4-40 cap nuts, except these are painted or plated army green.
Anyway, it's nice when things fall apart unexpectedly you find all the parts.... lol...
Not sure if the top on this thing is porcelain or not. Don't think the cabinet is, but there are no real signs of rust, so it must have been kept in a warm dry environment.
Speaking of which, time to roll it into shelter to continue its priviledged life...
