As I was packing to go home for the holidays, my Grandma told me to pack my screwdrivers because the control panel on her dishwasher was coming loose. (It is a 3-4 year old Point Voyager Maytag) Once I got it apart I realized that the plastic had cracked on the side and the screw posts that hold the control panel to the door liner were snapping apart. Again this machine is only 3 or 4 years old so a bit disappointing, especially since my 20 some year old Maytag made Maytag is chugging along My first gen Point Voyager KitchenAid also has not had any problems like this either. I think part of the problem is how the latch assembly is set up. This particular machine has the same latch as the models that had the top controls and the big grab handle...in this case there is no unlatching button to push you just grab it and pull, there is a spring in it and you have to overcome to force of the spring to open the door. In the control top models though the metal door panel runs the full length of the door so the grab bar is screwed into that metal panel which itself is attached to the metal door frame so all the force is routed through stronger parts. In Grandma's machine, you have to pull on the plastic control panel so the stress of overcoming the spring is being applied to the plastic panel. My KitchenAid has a latching mechanism, you push the button and it unlatches so all the force is applied to the button and not the entire panel. I know several other people here have these Point Voyager Maytag, has anybody else had this experience or was this just a fluke?
Cameron
Cameron
