Maytag dishwashers: Inside
@mark - THANK YOU!!! I love that they are even doing videos like that, but people that actually care about seeing them DO NOT want them sped up. The whole point is being able to accurately see what's going on, to be able to see the exact spray patterns and how the jets are aimed and what speed the arms rotate at.
Also, I think the question of "what is a reasonable lifetime for an appliance" is an excellent question that I feel can be different for each person. In my way of thinking, I think an excellent appliance would run flawlessly or near flawlessly (with minor repairs, like maybe a wash arm bearing) for 10-15 years. Some people may argue more, but my reasoning for that timeframe relies on a few factors. I think my aunt's WP PowerClean is the best example I have; excellent machine, excellent performance, build quality, design, etc. It is a MOL model bought in 2003 when the house was built, and has been running nearly every single day, sometimes twice daily, and has had no issues to speak of until very recently that it's begun making a horrible rumbling and sometimes failing to drain. My assumption is that the drain impeller may be chipped or broken or that something is caught in the chamber preventing the check ball from opening, etc. That's basically 13 years with no problem. Now, of course the machine can be easily repaired and can last for another 5, maybe 10 years, but at the same time, the design is showing its age. It's a magnificent dishwasher still to this day, but it was also designed alongside detergents at the time that had phosphates and worked properly with a 10-12 minute main wash. Detergents aren't designed for that now. All of us here know very well how to make a "vintage" machine do its job just as well as a modern designed one, but 99% of the rest of society don't care, my aunt being one of them. So in my honest opinion for her, it may be time to let the beast rest because she could care less about making sure to use heavier cycles or options to compensate for the time the detergent needs to work. That said, in 13 years, will my current modern WP still be "designed" to work with whatever chemicals we're using in 2029?
The other factor that comes to mind is that most people, myself included, get the itch for a "new" gadget even if the one they have works perfectly fine. If I have my dishwasher or washing machine for 10-15 years before a malfunction, I'll probably be MORE than ready to have something new and up to date regardless of how much I loved the previous appliance.[this post was last edited: 3/6/2016-00:54]
Very true about older machines and new detergents. With my Hobart KA, I now use powdered Cascade. I bought the ginourmous box at Sam's so I measure it into a disposable Ziplock container and add about half the amount in STPP. I think these powdered (and liquid) detergents are still being made with older machines in mind. You can tell just by reading the directions....the pacs say to use one per load, while the powder says to fill all detergent cups completely for best results. Older machines do wash faster and I can't even imagine using say, the Finish tabs in my machine. I honestly don't think they would dissolve completely by the time it drains...if anything I'd put it in the prewash compartment so at least it would be released early on. The Sam's pacs weren't too bad...I just used 1 in each cup, but they produced a lot more foam than the Cascade powder. They dissolved very quickly, as would the Cascade pacs I imagine...they look softer than the Finish rock hard tabs lol.
@ Andrew
Yes - I know exactly what you mean. I've been itching for a new front load washer for YEARS honestly, but my Duet keeps pumping out clean clothes with no issues! I like the cool new things too. But I also appreciate the fact that it's lasting as long as it has and does it's job, so I'm not about to get rid of it until it DIES!
Good point about the detergents now vs then, but I don't EVER remember (even the older dishwashers) having a main wash cycle that only lasted 10 to 13 minutes. I think my grandma's old WP 1984 dishwasher even ran an hour or so before the cycle was done? I may be wrong......I just don't ever remember those older 80s/90s dishwashers completing a cycle that quickly.....
Cycle times
Mark I think he meant the times that it washes in between fill and drain of each "wash". My Hobart KA has wash periods of about 10-13 minutes thereabouts. The whole cycle is longer of course, but they last about that long before it drains and fills again.
But how would it even have time
to heat the water with 10 to 13 min's between drain/fills?
Maybe I just never paid that much attention with past dishwashers - but I know when the cycle was done, you opened the door, steam poured out...so I assumed the dishwashers were heating the water regardless if they had a hi temp wash button or not...but I would think it would need to run longer than that between fills and drains to heat the water.....I dunno. Maybe I'm just remembering wrong.
I honestly don't remember on machines from when I was a kid. Mine now has a water heating light and it heats the water for about 15 minutes first before the first wash. Other washes it doesn't though, as far as I can tell.
If I'm not mistaken, that was Whirlpool's very first iteration of any silverware "focused" feature that wasn't just aimed nozzles on the wash arms, and I think they're the first to have tried and succeeded with that feature as well. I can't seem to find any documentation of any dishwasher manufacturer that had anything like the TurboZone or Silverware Blast before Whirlpool first had them on their machines. They've come a long way with it though; the silverware spraybar in my machine now has much better coverage and seems to address any issues with the basket being built onto the door. I think it's cool to see that in the Maytag, they used the same coupling on for the silverware blast that was normally used for the PowerScour/TurboZone bars. Same little junction with steel balls that were magnetically shifted to redirect water from the upper arms to the other spray zone. I would have loved to have one of those machines when they were available. I wonder why they stopped offering it as a feature by the time Mark and I got our Maytags.
Wash times
I just listened as my KA went through a normal cycle. It did two 10 minutes washes and two 5 minute rinses. Before the first wash it heated the water for about 15 minutes, then the wash cycle started. The whole cycle time is about 1h15m that includes start to finish with heated and fan dry.
I just did a bobload of dishes today in my Maytag
and I timed it using autoclean. I guess it really does do soil sensing because using ONLY the autoclean option, it rain 103 minutes with no dry......the last time I ran autoclean it ran 91 min's with no dry.
@ Andrew - I wondered the same thing when I watched that video. I kind of wish my silverware holder was in the door for more room. But I often end up just putting stuff on TOP of the silverware holder itself, since there is enough vertical space to allow clearance without blocking the upper spray arm, and they still come clean......
Those times are similar to my Frigidaire. It's a decent machine actually...new features but it doesn't take forever to wash.
Bob load and no pics?? Wth Mark! ;-)
