M mb1974 Well-known member Platinum Member Joined Jun 23, 2021 Messages 64 Location pa Feb 2, 2025 #2 The timer dial on my 2008 Maytag dryer moves intermittently. Could lubricant help the timer move more smoothly? Thanks.
DADoES Well-known member Platinum Member Joined May 21, 2001 Messages 15,783 Location TX, U.S. of A. Feb 2, 2025 #3 Are you using a timed or auto-dry cycle? Thermostatic auto-dry has the timer running only when the heat cycles off so intermittent movement is normal.
