Maytag Epic inner tub movement/play
dnastrau
Apr 9, 2007
763
Lords Valley, PA
Greetings:
I recently noticed that our 2007 Maytag Epic 9700 (Whirlpool Duet clone) has a bit of play in the inner tub if I push it up at the top (and it isn't suspension movement). I can feel just a slight bit of play. Is this typical?
My first thought was that the tub bearings were going out but I don't see any signs of leakage around the drive pulley (at least with what I could see using a digital camera - not much room back there - see photo).
Is it possible that the inner tub-to-spider connections are loose? Is the spider connected to the inner tub with screws/bolts on one of these?  The machine is performing just fine with no funny noises, etc.
Thanks for any thoughts on this.
Andrew S.
Thanks for the replies Eugene and John
No unusual noises during spin but very occasoinally I can hear a brief squeak (sounds like rubber) when the tub is turning slowly during agitation.  I chalked that up to the rubber seal on the tub bearing making noise against the rotating spider shaft.  I noticed that at least a year ago and it hasn't gotten worse.  Overall, performance and noise is the same as it was back in 2007.  I will just ignore it if nothing changes.  It has been a very reliable machine for us with the only maintenance having been to clean the pump trap a few times and to soak the water inlet screens in CLR once in awhile.
Andrew S.
