Tide Washer Cleaner generates bunches of suds in my experience with it, and the instructions state to run it on the Normal cycle, not a designated Tub Clean cycle. Splashless and scented chlorine bleach products may also generate sudsing. Affresh does not, and Lemishine (which is citric acid) does not.
Tub Clean cycles typically fill to a higher level and run the drum at distribution speed to slosh the water around more vigorously, which increases sudsing with products that cause it, and increased possibility of leaking from the tub vent.
