Maytag Help in Florida
toploader55
Oct 10, 2007
7,091
Massachusetts Sand Bar, Cape Cod
Hi.
I am visiting my parents in Florida. The Washer is leaking oil. I am in the Sarasota Englewood area. Does anyone know of a repair service that would fix this seal and not tell them the machine is junk ? It is running very smooth and quiet so far.
I would say this just started as there was no oil on the floor last winter when they used it. The machines came with the house and they love them.
Any help would be appreciated.
I don’t recall but are there any members that would want to do this repair for a fee ?
Thanks.
The other option is finding a donor machine to take the transmission out of it and use it in this? Its a teardown but why not rebuild the machine with a new seal, dampers, and everything while youre down there. Make it last another 30 years.
Well, I am only here for a few weeks and I don’t have time or the knowledge to do the rebuild. Dishwashers ate a bit easier
I am going to call around on Monday and see if I can find someone to repair it.
Thank you for your thoughts.
I was thinking along the same lines....
shop some local used appliance shops and see if you can find a donor...
but just flip the top over to the new base unit.....
just mark and disconnect the wires from the water valve and the motor....and re-attach in the new base....
in under an hour you will be back in action....
That looks like a 12 series or later machine which should have the replaceable low lip seal and does NOT require any major disassembly.
Looks like this:
Relatively easy fix for an honest repair tech.
Maytag Leaking Oil
As Mark suggests, don't repair, just clean everything up, put on a new main drive belt and sit the washer on a piece of low pile carpet or heavy cardboard [ to catch any oil that drips ] and let the washer run, I do this all the time with old leaky MTs and they have usually run another 5-10 years without doing anything.
Next best thing would be putting in a new transmission, top seal assembly, lucubrate the damper, replace the inlet valve, replace the little rubber thingy in the inlet air-gap [ $500.00 ] and then you have a good shot of the washer lasting 5-10 more years, till the timer gives up or the outer tub rusts out.
John L.
could also just blast the bottom with degreaser
That is no slow oil leak, it's all over the pulley, belt and perimeter of the base plate.
Should be properly repaired with a new lip seal and lube the damper pads while opened up.
Maytag revised the seal so owners didn't have to live with the Exxon Valdez under their washer.
