chef
Active member
The agitator shaft has this collar pressed on instead of one piece cutting it on the lathe? Why pressed on? It looks like brass?
Those 3 vertical groves on the aluminum upper transmission tube housing. What are those for? The water is getting past the seal and spanner nut which causes the corrosion on the aluminum upper transmission tube housing threads?
