billythekid
Working on a Maytag LAT4916AEE and I'm planning on lubing the damper pads as a maintenance item (no current balance problems). Due to it's composition, Permatex Dielectric grease will be used. Now comes the question of pad condition and the lube process. After reading posts here RE these pads it's understood that replacement is needed if the pad(s) is wore through or the glue has broke loose, but how about pad compression due to age? Is compression a reason to replace? And how about glazing, is cleaning the pads (rag w/solvent) then breaking the (silver colored) glaze by gently brushing with a brass brush appropriate? Finally, just how much grease is needed? I see some pad replacement kits include two pillow packs of grease, some include three. Would the equivalent volume/weight of two full pillow packs be appropriate? Thanks.
