bradross
Hello everybody,
Some of you may recall that I had been looking for a Maytag "grey ghost" pump model. Well, I found one in Pennsylvania on etsy.com and had it shipped to the west coast in September.
Most of the structure was in sound condition - only surface corrosion in the wash tub (no pitting) and the wringer rolls were in amazing condition! However, the agitator post(pipe) was cracked, resulting in water ingressing down the shaft into the crankcase, and the agitator drive shaft was seized. The pump was seized with corrosion, sediment, and string/lint wound around the impeller; that was relatively easy to restore. The drain hose was rotten and literally falling apart. But after approximately 85 hours of work, she's a beauty and fully operational now.
Here are a few pics of the finished work. The entire restoration is documented on Flickr, if you're interested.
http://https//www.flickr.com/photos/44623676@N05/albums/72157658774939800
