Maytag Neptune Dryer Intermittent no heat problem
moparwash
Bronze Member
Aug 26, 2007
1,838
Pittsburgh,PA
Before I run out and replace thermostats and gas coils willy-nilly, I thought Id run it here first:
This happens on timed and auto-dry cycles
Sometimes no heat when starting
Sometimes heat goes out while running
Sometimes it has heat all the time
The heat is really hot...much hotter than its DG108 neighbor
And its just 20 days out of warranty from the used appliance place I bought it from!!
You should be able to open the front panel and watch it run to observe. If the igniter comes on then goes out without the gas lighting, then you most likely have bad coils or the wire connectors at the coils might be loose. If the igniter does not come on, then you might have an issue with that, the flame sensor or maybe a thermostat...
RCD
