dustin92
I picked up a 2001 Neptune a couple weeks ago off of a facebook freebie group. The owner said they had just bought the house and the previous owners had left it but said it worked fine. I drove about 40 miles to pick it up, and expected it to need some kind of work. Nope. Works perfectly and is in excellent condition! Even got a huge brand new dispenser jug of Arm and Hammer detergent with Oxi Clean that they said they wouldn't use. It Was extremely smelly and orange inside, so after a very long hot wash with a LOT of bleach, and a very good scrubbing of the boot and bristle seal it was ready to wash. No more smelly. This thing works amazing! I've never had cleaner clothes from a front loader, and it spins super smooth and quiet. After a few loads in the basement to test everything out, it got moved to the upstairs laundry room and it's staying! Controls are super versatile and it will do anything you ask it to, and it cleans amazingly. Doesn't mess around going into spins, rinses great. When I set it for extra rinse (only when I do whites with bleach), almost no bleach smell is left in the clothes. I do have a leaky hot fill valve, over 24 hours, it fills with 2-3 inches of water. I just shut the faucets off when I'm done with laundry, no big deal but I do plan on changing it eventually. I also have it plugged into a switched power strip so the door can be left open to dry out inside. Are there any major issues I should be watching for or is this machine as solid as it seems to be? Bearings sound great at this point. I'm getting a slight, intermittent knock during wash (usually only hot) and at slow spin speeds (as it's distributing for spin probably). The only thing I've done to it was replace the drum light which was burned out. Other than that, It works amazing and I really enjoy using it.
