orbital-fan
Folks, I have a Maytag LAT9520AAE topload, 2 belt automatic washer. Long story short, I ran it for a while knowing that water was entering the transmission. I finally removed the transmission, found "mustard" inside, and as it happens, found the internals in pretty good condition, notwithstanding the poor lubricant. Trouble is, with this water / hypoid oil mix - the upper bushings (for the agitator shaft) and the lower bushings (for the input-drive shaft) have become sloppy. I figure I ought NOT to simply install a new o-ring on the agitator shaft and a new lip-seal for the bottom of the input drive shaft - and expect those seals to perform properly when THEY are causing the respective shafts to turn straight (i.e. when there is considerable radial clearance with the bushings).
Do any of you folks know where I can get new oil-lite (I presume) or brass or bronze bushings to properly restore the fit?
I do not want to junk my machine on this basis... but I do NOT want to buy a new transmission, as I already need a new stem seal, top bearing, bottom bearing, clutch bearing, and agitator.
TIA!
Orbital-Fan
TIA!
Orbital-Fan
