dustin92
We have been having a random issue with our Maytag performa set, which is that one of the machines is cutting clothes, a couple things have gotten slices in them, the first item beong a zip up hoodie of mine, which I wore to work a lot in the winter, and when I noticed the cut, right around the bottom, I thought I had hit it with a box cutter. About a 3 inch gash all the way through one layer, and partially through the second layer. Other items are just getting small, jagged holes in them, almost like moth holes, but in clothes that are worn regularly. (a few T shirts, Sweat pants, a very nice set of cotton sheets, and some random socks). One of my good polo shirts got a cut in it almost identical to the hoodie, right across the buttons. I'm not sure where the cuts are happening, whether in the washer or dryer, but both machines seem to be working properly, and don't have any noticeable sharp edges. The only area I even questin is between the top and bottom of the 2 piece agitator, it seems to have some up/down movement, and I am wondering if the clothes are being pushed into there, and getting cut. If we can't figure out the problem, I think I will give the downstairs set (Speed Queen pair from 1989) a tune up, (the washer needs a new belt and possibly a timer, and the dryer needs rollers), and switch them out with the Maytags upstairs. I don't really want to swap them, because the Maytags have better capacity and are quieter, but I don't want to destroy all of our clothes and bedding either!
