Maytag (Point Voyager Pics) After Citric Acid Cleaning
mark_wpduet
Dec 29, 2008
2,662
Lexington KY
So my Maytag is about a year and a half old now and I ran to longest cycles with the main detergent cup full of citric acid. It's an awesome dishwasher and I've never had a problem with it cleaning. I use finish powerball and a splash of bleach and jetdry in the rinse aid and everything comes out great. I've always noticed the screen under the lower wash arm has always had sort of a skim over it. After this citric acid wash, the screen looks really clean EXCEPT the very edges of it (if you notice this in the pics) What is this? Whatever has been on the screen has not affected the washes at all. Should this be cleaned by me and if so, is it easy to take off and clean? I know you can unscrew the lower wash arm but I have never gotten beyond that point for fear that I would screw something up that works great.
As long as water can circulate through the filter and back into the sump I wouldn't worry about it. Sometimes crud can build up on the underside from accumulated food soils, but as long as the spray holes on the underside of the wash arm are clear they should backwash it reasonably well. The filter does come out fairly easily though, you unscrew the wash arm and lift it out. There are 4 torx screws that hold the filter/sump grate in place. One of them is under the feed tube for the upper wash arm though. You'll have unclip or unscrew the feed arm depnding on how yours if set up, then twist the feed arm clockwise and it will pop off the main water feed revealing the 4th screw. Then you can lift the sump grate out and from there just pop the filter off the top of it. If you do clean the screen be careful with it as the mesh is kinda delicate, breaking it will affect the performance of your machine.
Cameron
Screen Edge Crud
That stuff was always there on my parents' old GE XL.
It was usually small amounts of food deposits, minerals and lint. The cleaning jets just couldn't get to the very edges, but as long as the majority of the filter screen is clear, it's good to go!
CleanteamofNY user
on here gave that tip. He just said he adds a splash of bleach to the door before he starts the cycle. When I say splash, I mean, like a shot glass worth, then close the door, start the cycle. By the time the main wash starts and the finish powerball is released, most of the bleach has been washed away.
When I started doing this, I could tell a HUGE difference in how much cleaner the interior of the dishwasher looked and it had that super clean sanitized smell at the end of the wash more so than if no bleach had been used. I was a little skeptical doing this at first, but it works GREAT sanitizing dishes and keep the inside of the dishwasher cleaner. But I wanted to to the citric acid (or, what I used was diet lemonade drink mix) to clean any hard water deposits. It shined like new when the cycle was done, but I noticed that screen had a little bit on the edges, which is my original reason for posting.
during the wash yes
but not at the end.....I tried something else today because I ran a load. I have this STPP that I bought a LONG time ago and it's got to be at least 3 or 4 yrs old. It's about 1/2 remaining so I added some in with the finish powerball. I still added a bit of bleach in the beginning. After the wash was over, and I opened the door to let things flash dry, there was hardly a water spot to be found on any of the stainless steel. It wasn't really that bad before, but you would tell phosphates were added by the look of the machine at the end. I guess they still work even as old as this batch I have is.
I believe that STPP eventually morphs into TSP as it ages?? I know TSP is what is recommended in the dishwasher...but not washing machine. Where as STPP can be used in both.
I still put STPP in every load in my dishwasher. I think it really makes a difference in getting rid of any residue. My dishwasher looks brand new inside. Granted it's only a year old, but! lol
Mine does too
except for that small screen under the lower wash arm..on the edges.....That's why I'm going to start using phosphates again to see if that will go away. It's washing and cleaning great, but that screen crud bugs me a little.
Adding Bleach At The Beginning Of The DW Cycle
Can help, but the way I get the benefits of bleach is by putting liquid DW detergent in the first cup that contains bleach, in addition to the benefits of bleach you also get a boost to the overall cleaning of the DW by having detergent in the first wash. I also put a tablet in the main wash cup and close it.
I have been using Aldis Reeva DW gel for the prewash, it is only about $2.50 for a 75oz bottle.
At my partners house I have used nothing but the Aldi detergent in both cups of our 1987 WP Power Clean DW for the last two years and it works great, but we have a water softener system there so you don't need the more expensive tablets etc.
I haven't used GEL
dishwasher detergent in FOREVER! How can gel have chlorine bleach in it and no phosphates? I thought all modern dishwasher detergents had to have enzymes since phosphates were not allowed. I did not think you could have bleach/enzymes in a detergent as that would cancel it out...I realize you put a tab in the main wash, but most people probably who use gel would just use the gel and that's it. I wonder how the gel cleans if it doesn't have enzymes?
I do the same thing as Combo
in my 1994 KDI23.  I'll fill the first wash cup about half full of some gel or powder with bleach in it and put a tablet or pod in the main wash cup.  I'd use gel in both cups but I've found that the spray is so powerful in the KA that the gel gets washed out by water getting under the cap!  This cap doesn't have a gasket under it (that I can see) like the Jetclean does.  I did the same thing in the Jetclean with gel and a tab.  We also have a water softener...and I think some of the tabs are too strong for softened water. My Mother uses gel with bleach in her KDI23 too.  No complaints from her for 22 years!
"I wonder how the gel cleans if it doesn't have enzymes?"
Very well!
Combo, I'll have to look for that at Aldi.  I don't go there much so I'm not familiar with all their stuff.
Interesting
I wonder how if it's phosphate free and enzyme free it cleans dishes? I thought you had to have one or the other based on what I've read. I read the label and it does contain bleach. I knew the gels used to have bleach back in the day. You could smell it but it also had phosphates. I may try adding a little of this to the prewash with finish powerball in the main cup.....but I'm thinking that would essentially be the same thing as adding a splash of bleach when you start the wash.
The downside is those bleachy old formula detergents will fade patterns and designs on your crockery.
It does remove stains but the whole purpose of modern day detergent is the ability to do that without chlorine.
I have some old dishes that were handed down from my grandmother and I keep them largely for sentimental reasons but they'd are bleach damaged from 1970s/80s dishwashers.
She would have used Super XM and probably old versions of Finish and Sun powders and gels that were very bleachy formulas.
If your machine is running hot enough you shouldn't have any issues with buildup.
I suspect running endless Eco cycles will cause crazy gunking up in dishwashers. It's not something I've ever tried !
The Cascade pods and powder with the Clorox logo on them DON'T say chlorine on them....so why Clorox has their signature on them is beyond me.  I looked at some today and read the ingredients....sodium silicate, sodium carbonate, and enzymes.
The MSDS on PG website lists Carbonic acid disodium salt, compd. with hydrogen peroxide....I guess this is where the "stain fighting" comes from.
The gel says...sodium silicate, sodium hydroxide, sodium carbonate, and chlorine bleach.
I've honestly always been afraid of using bleach or vinegar regularly in a dishwasher or washing machine, because of the effect it has on the seals and such. I just use either Cascade Complete pacs or Finish Powerballs with good Jet-Dry, and I never have any troubles at all with cleaning or smells. Every other month or so, I'll run a half load or so of dishes that aren't terribly dirty, along with the mesh drain strainers from the sink, and they get a Heavy/maxed out options cycle, and I'll put a splash of bleach in for the prewash, just as a periodical "maintenance" cycle. Really though, the Maytag and WP PowerClean both keep themselves so clean even with the filth they see regularly that I've decided to keep the harsh chemicals to a minimum.
Good point
but the amount of bleach I use is so small and it gets flushed away quickly...but you're probably right about keeping harsh chemicals to a minimum.
most of the cleaning power in
new detergents is high alkalinity + enzymes. They keep trying to improve enzymes that will work in higher and higher alkaline systems. You search the current patents for enzymes and its all aimed at more alkaline durable enzymes.
Mark is right bleach will stop enzyme action asap. So keeping those two separate is they best way to use them. That is if you want enzyme action AND bleach action.
Anybody remember the old smell of Cascade back in the 60-70's? It smelled wonderful in a machine running. Somehow in changing the formula completely they have lost that smell. Anybody have a box of 1960's cascade with the ingredients?
[this post was last edited: 12/17/2015-07:44]
What smell?
I wasn't alive in the 60s, and being born in the early 70s, I can only remember things from about 1976 and forward.....anyway, I always remember the sanitized chlorine smell when the dishwasher was running.....I don't remember any other smell.
what did the 60s detergent smell like other than chlorine?
I guess I'm not so paranoid about using a little chlorine because that was an ingredient in dishwasher detergents for AGES, and dishwasher that used them lasted a long time.....Then again, the were built better....LOL
Mark, does your Maytag run two prewashes? Because my Bosch does a heated prewash, drains and then fills for the main wash. I wonder if residual chlorine bleach would kill the enzymes?
Logixx
I don't think it does 2 prewashes, but it does a purge after the prewash and fills with some water then drains before the main wash.....I was afraid of this too, remaining bleach killing the enzymes, but it's not.. It still works great. I think it's too small of an amount of bleach I'm using, add to the fact that it's diluted with the prewash and purge before the main wash, most of it's gone when the main wash starts. Like I said, the last time I ran a load, I added phosphate power in with the finish powerball main wash section, and at the end, the interior of the dishwasher looked spotless, I mean noting but shiny stainless. With just the powerball, you could see water spots on the stainless.
Cascade smell
One of the Cascade POD's that comes up every so often mentions that "you'll love Cascade pretty green color and pine scent" or something to that effect. But I do remember that it had the best fragrance when the dishwasher was running.
