Maytag Poly-Lube
mandorob
Aug 2, 2014
24
I'm having a hard time locating some poly lube and wondering if anyone can tell me of a readily available alternative. It can't be that magic of a lubricant, perhaps there is a hardware store substance that is similar enough?
Thank you,Rob
Go To:
A bicycle shop or sporting-goods store that carries bike supplies and ask for Park Poly-Lube. Bike owners use it.
A big tube is about ten bucks. I got mine at Scheel's Sporting Goods here in Waterloo.
Thanks, that came up in the searches but I didn't know if it was similar in composition or just had the same name.I'll give it a try.
Works Fine!
I don't see or feel a difference between the Park stuff and what comes in the little pouches included with a Maytag damper kit.
BTW, if you're wanting this to lube Maytag dampers, the damper pad kit should come with three little pouches of the stuff - one for each pad.
It looks to me as though thread 50735 only has 19 replies.
poly tube
I wouldnt use anything but polylube on damper pads,it is still available through whirlpool.Call grays appliance in Melrose mass they know the part number.
